USB connection
22 Jun 2020 15:32 #172362 by dlw
USB connection was created by dlw
Newbie here.
Just purchased a 3040 cnc machine.
Trying to use LinuxCNC to run it.
Went through 'stepconf'.
When testing X, Y and Z axis, there is no movement for any of the axis.
When buying the machine, it was posted as being able to use USB to run the stepper motors.
I plug a usb cable into the PC and the controller. Nothing moves.
How do I go about solving this?
dlw
  • Moderator
  • Moderator
22 Jun 2020 15:46 #172364 by tommylight
Replied by tommylight on topic USB connection
Through USB nothing will move, ever. LinuxCNC does not use USB for control.
But do some pictures of the controller board and the electronics, most of them can be easily made to work with LinuxCNC
23 Jun 2020 02:04 #172412 by dlw
Replied by dlw on topic USB connection
But do some pictures of the controller board and the electronics.
Does this mean opening the box that came with it?
If so, should I post them?
  • Moderator
  • Moderator
23 Jun 2020 07:14 #172431 by tommylight
Yes and yes.
24 Jun 2020 00:31 #172519 by dlw
4 photos attached.
dlw
24 Jun 2020 00:33 #172520 by dlw
I ordered a usb to parallel cable.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
24 Jun 2020 02:00 #172525 by BeagleBrainz
Replied by BeagleBrainz on topic USB connection
Still wont work with Linuxcnc
  • Moderator
  • Moderator
24 Jun 2020 09:18 #172553 by tommylight
Those are simple step/dir drives so they can be used with a parallel port for 10 to 15$, but not with an USB to parallel adapter.
You can buy an add on PCI or PCI-E parallel port card, or even better get a Mesa 5i25 (PCI) or 6i25 (PCI-E) or 7i92 (ethernet)
24 Jun 2020 13:48 #172585 by andypugh
Replied by andypugh on topic USB connection
We should also mention the possibility of running the machine as-supplied through a USB connection and not using LinuxCNC at all.
It will probably work fine with a pirated copy of Mach3 and a pirated copy of Windows, as was probably supplied with the machine.
  • Moderator
  • Moderator
24 Jun 2020 14:02 #172588 by tommylight
Does not seem he got any of those with the machine, at least he never mentioned it, but he did say he ordered an USB to parallel adapter, so now that might be a possibility.
Time to create page: 0.163 seconds
