- LinuxCNC
- General LinuxCNC Questions
- 7i76e MESA two MPG / or potentiometers or digital spindle speed / feed override.
- dsergison
22 Jun 2020 16:15 - 22 Jun 2020 16:32 #172368
by dsergison
7i76e MESA two MPG / or potentiometers or digital spindle speed / feed override. was created by dsergison
I have a i Mach PS$ USB MPG pendant running with debian 9 and linuxcnc 2.7 and 7i76e Mesa and I use the 0-10v analog spindle control open loop and that's great... but I also want other external override controls over spindle / feed.
Can I connect two override sources into linuxcnc? I could use a second mpg or a digital signal..
I know that If I had a simple potentiometer and I turned the speed up or down with the mpg pendant that would conflict with the pot... so two mpg would solve that but I want to eventually control the machine spindle with a sort of vision system for quality control.
Thanks,
Thanks,
Last edit: 22 Jun 2020 16:32 by dsergison.
- Thank you received: 7468
25 Jun 2020 12:19 #172716
Replied by tommylight on topic 7i76e MESA two MPG / or potentiometers or digital spindle speed / feed override.
Yes you can, sorry for the late reply.
Mesa 7i76E has two inputs for MPG, so you can set them in hal to do whatever you need them to, it is just a matter of connecting them in hal.
Maybe you can find something here to point you in the right direction:
www.google.com/search?source=hp&ei=MZb0X...n4CE8Q4dUDCAY&uact=5
- LinuxCNC
Time to create page: 0.188 seconds
