Recommendations for modern servo driven PM-833 mill build
- sharkat
23 Jun 2020 00:47 #172409
by sharkat
Recommendations for modern servo driven PM-833 mill build was created by sharkat
I'm setting up a PM-833TV for cnc and I'm pretty set on Linux CNC at this point. I need a system with two Nema 34 and one Nema 42 servos. I've seen that the 7i96 seems to be the new go-to board and I'd probably pair that with DMM DYN4 drivers and servos but I'm curious if I'm missing better options in the same ~$1k board+servos+drivers price range. Delta has the ASDA-B3 series with Ethercat which is compelling from a wiring perspective but best I can tell the system prices are at least 2x what the delta system would cost. Is EtherCAT worth the upgrade cost? I'd also like to avoid having to have a separate power supply for the servos and just run everything off one 220v "2ph" line.
Any thoughts are welcome!
- Online
- Thank you received: 7468
23 Jun 2020 07:10 #172430
Replied by tommylight on topic Recommendations for modern servo driven PM-833 mill build
7i76E would be a better choice for a mill as it also has full isolated spindle control.
The following user(s) said Thank You: sharkat
- sharkat
23 Jun 2020 23:10 #172516
by sharkat
Replied by sharkat on topic Recommendations for modern servo driven PM-833 mill build
What are generally considered to be the least painful/best value servos to work with? I see recommendations for DMM, Delta, ClearView and a couple others. Is there any consensus as to what's easy to integrate with the mesa boards?
- Online
24 Jun 2020 09:05 #172549
If money is not important, i would go for Yaskawa or Delta.
But beware that they have so many different types that it is really hard to know what to get.
- sharkat
25 Jun 2020 04:06 - 25 Jun 2020 04:06 #172685
by sharkat
Is there a good way of determining what torque and power rating I need? The head is relatively heavy but I intend on adding a counterbalance to lower the force needed and reduce the wear on the ways. X and Y are extremely easy to turn given the oiler. even deep cuts in steel are relatively easy. It's an 800lb machine.
I'm looking at something like either 250W 0.8Nm, 2.4 peak XY and 750W 2.4Nm, 7.1 peak Z
or
750W 2.4Nm, 7.1 peak XY and 1.3kW 4.98Nm, 15.0 peak Z.
The latter is much closer to what others have done using steppers but those power numbers seem extremely excessive to the point of possibly being dangerous.
or
Last edit: 25 Jun 2020 04:06 by sharkat.
- Online
25 Jun 2020 11:51 #172706
Hurco BMC20 uses 750W Yaskawa on all axis as it has a counter balance on Z and that is a 3.5 tones machine, so i would think that 400W should be enough.
Take this as advice, not the definitive answer, there are more experienced users here for servo systems, i mostly use steppers.
- sharkat
25 Jun 2020 17:33 #172739
by sharkat
Thanks for the info, that's good to know. I'm trying to get into the ballpark first so I'm just looking for some coarse guidance to get started.
Time to create page: 0.121 seconds
