What servoController to use with B&R servo's with EnDat 2.2
28 Jun 2020 18:11 #173012 by Aciera
Just as a quick sanity check:
www.aliexpress.com/wholesale?catId=0&ini...t=servo+system+10Nm+
But really 1.5kW to move an axis for a laser? And you are looking for 6000 rpm!
  • Moderator
  • Moderator
28 Jun 2020 19:47 #173023 by tommylight
[edit2]
I meant to write STMBL drive.
As far as i know that project is dead for now, still no new power chip for it they say, but a quick search resulted in several similar chips with similar or better parameters for quite cheap.
A while back Andy linked me to some documents and some quotes for boards and parts for them, not cheap, but then again not expensive for what they offer. Now again i am in the process of waiting for some quotes to see if something has changed, but i would like to change the layout of the boards and mounting options and just have no time for it.
I did work with Argon drives and they seem to be the same exact thing with a bit more user friendliness into them.
Let me know if you have interest in pursuing them.
29 Jun 2020 04:14 #173052 by Aciera
They have actually changed the design to discreet power transistors but are still in the testing phase.
Thanks for the info on Argon drives I'll have a look at that since I still need something for my mitsubishi robot.
Time to create page: 0.092 seconds
