Sth. like "Feed Override" which also effects G0
6 years 4 months ago #173009 by mydani
is there by any chance sth. to use to control both, feed and G0 speeds by external potentiometer?
Just when running a code first time having feed override and hands on poti is great, but G0 is not affected.
Thanks for hints.
Regards,
Daniel
6 years 4 months ago #173010 by Aciera
I use a panel button to enable and disable rapid feed override by setting halui.rapid-override.direct-value true or false, the actual analog feed value comes in with the signal poti-feed-scaled:
# ---Potentiometer RAPID-speed Override net rapid-override-en-panel => toggle.rapid-override.in net rapid-override-enable <= toggle.rapid-override.out => halui.rapid-override.direct-value net poti-feed-scaled => halui.rapid-override.scale
6 years 4 months ago #173037 by cmorley
You could use the same potentiometer input to control both feed and rapid override or
look up max velocity override it affects both.
Time to create page: 0.268 seconds
