LinuxCNC is Running......?
- hoffb77
- Thank you received: 21
08 Jul 2020 16:43 #173993
by hoffb77
LinuxCNC is Running......? was created by hoffb77
I've been looking for a signal in hal that activates the moment the interface(EMC2) is executed and stays on until it is terminated. My intent is to use that signal to notify the PLC that the interface has dropped out. I've been looking for it. Maybe its right in front of me and I dont see it.
Right now as is stands, the PLC will enter fault status once the drives indicate a following error, which safely stops the machine but I would like to add that signal to my control loop and have a unique indication.
Thanks, Ben
Thanks, Ben
- Thank you received: 7468
08 Jul 2020 17:56 #174003
Replied by tommylight on topic LinuxCNC is Running......?
Charge pump is used for that, see:
linuxcnc.org/docs/2.8/html/man/man9/charge_pump.9.html
- hoffb77
08 Jul 2020 19:05 #174009
by hoffb77
Replied by hoffb77 on topic LinuxCNC is Running......?
Thank you Tommy.
I thought maybe something was in the default servo thread I wasn't seeing.
I imagine I could add it to the servo thread instead of adding a base thread. I do not require a squarewave pulse. A digital signal will suit my purpose.
08 Jul 2020 19:50 #174019
Yes you can add it to the servo thread, and the frequency will be lower (1kHz max), but it will work.
If you do not need a square wave, just add a 10uF capacitor to the output of the charge pump, and test if whatever has to be shut down by it, shuts down immediately. If it has a delay, try a 1uF or lower value.
- hoffb77
08 Jul 2020 20:16 #174023
by hoffb77
I dug into the functions man pages once you mentioned the charge pump. It looks as if the watchdog.ok-out (if enabled ) will serve my purpose very well.
- hoffb77
08 Jul 2020 21:16 #174031
by hoffb77
Looking at the mesa watchdog function....it has a pin has_bit, I will work off this for now and report back.
- hoffb77
09 Jul 2020 04:19 #174051
by hoffb77
Seeing as has-bit kills all outputs to original state that wont quite work. I have set an output true when the thread starts. That will be enough for now.
09 Jul 2020 08:14 #174069
You might be able to set that same output to false in the shutdown.hal, so it should go low when exiting LinuxCNC.
But that will not go down in case of a crash, but that does not happen ever with Linuxcnc. If it starts and works, it will work, even if something else in Linux goes down, LinuxCNC will continue to run.
- hoffb77
09 Jul 2020 14:51 #174097
by hoffb77
You are correct. In the 10+ years I have been running machines on this interface I never had a failure due to emc2. I've had a few PC power supply failures and brain farts are ten fold.
My current setup signals an Estop to the PLC in the event of an ethernet disconnect or a PC crash. And thats what I need.
Time to create page: 0.220 seconds
