CNC Tool Transform
10 Jul 2020 19:06 - 12 Jul 2020 13:59 #174251 by jcoahran
CNC Tool Transform was created by jcoahran
Do you use Fusion 360, along with Path Pilot or LinuxCNC?
Maybe this tool can help. It converts mill tool libraries between these platforms. It can create a new, or update an existing library based upon common tool numbers.
For new libraries, I add tools to PathPilot, use an electronic tool setter (ETS) to quickly measure each, then transform the library to Fusion 360, eliminating the need to re-enter the same information. You might prefer to create your tool library in Fusion 360, then transform it to PathPilot or LinuxCNC.
Occasionally, I re-measure high-use tools using the ETS in PathPilot, then update my existing Fusion 360 tool library. Doing so only updates the tool length, leaving feeds/speeds, tool holder, and other properties as set, again eliminating error prone duplicate data entry.
Mill tool libraries are supported. Lathe support is in the works.
Are there other platforms you'd like to see supported? Find bugs? Please send a note to admin at islandcnc.net.
Thanks!
apps.islandcnc.net
Last edit: 12 Jul 2020 13:59 by jcoahran.
  • Moderator
  • Moderator
10 Jul 2020 19:16 #174254 by tommylight
Replied by tommylight on topic CNC Tool Transform
Tried uploading a tool.tbl with valid tools, it just kicks me back to the main page.
10 Jul 2020 19:19 #174255 by jcoahran
Replied by jcoahran on topic CNC Tool Transform
Can you please send me a copy of your tool library to admin at islandcnc.net?
  • Moderator
  • Moderator
10 Jul 2020 19:26 #174257 by tommylight
File Name: tool.tbl.zip
File Size:0 KB
10 Jul 2020 19:31 #174258 by jcoahran
Thanks, debugging now.
10 Jul 2020 19:50 #174261 by jcoahran
None of the tools in your library have a Z length. Is this common? My code is currently designed to ignore tools without a length. Should I default it to 0?
  • Moderator
  • Moderator
10 Jul 2020 20:11 #174263 by tommylight
Yeah that might be it.
Leaving it at 0 does not seem like the smart move and is not usefull, so leave it as is.
Thank you.
