homing mesa 5i25 and 7i77
- Artur_1617
- Thank you received: 5
10 Jul 2020 21:03 #174273
by Artur_1617
homing mesa 5i25 and 7i77 was created by Artur_1617
I start to play with homing on encoder index but does work.
when I push buton for homing, X axis start to moving but dont stop pressing home switch on X axis
For now I play only with X axis.
Home input is connected to mesa 7i77 to pin-07 and when i press him I see change from False to True
- Thank you received: 5321
10 Jul 2020 21:13 #174275
Replied by PCW on topic homing mesa 5i25 and 7i77
Have you verified that index works?
- Artur_1617
11 Jul 2020 09:13 - 11 Jul 2020 09:24 #174288
by Artur_1617
Replied by Artur_1617 on topic homing mesa 5i25 and 7i77
I think I have problem with homing input.
For me, when axis press home switch must stop and start moving in
opposite direction looking index pulse...
Last edit: 11 Jul 2020 09:24 by Artur_1617.
11 Jul 2020 15:49 #174309
If you want the search for index to be in the opposite direction of the home switch
search, the HOME_LATCH_VEL must have the opposite sign of HOME_SEARCH_VEL
linuxcnc.org/docs/html/config/ini-homing.html
The following user(s) said Thank You: endian
Time to create page: 0.097 seconds
