Using it 100% from the console
6 years 3 months ago #174631 by felixcnc
I want to use LinuxCNC in very old systems so I would like to avoid using the Graphic UI. So basically I would like to write the HAL I am going to use and configurations and get the kinematics calculations to move my robots but without any graphical interface.
Is that possible? If so, can you point me to the right direction on where to check and learn more about this?
Thank you very much
6 years 3 months ago #174679 by rodw
Replied by rodw on topic Using it 100% from the console
typing "man halui" should show you what you need to use. It is in the html docs down the bottom of the html page if you click on expand.
Also a Mesa 7i73 might be useful if you are using a mesa card..
Time to create page: 0.301 seconds
