Linuxcnc questions
- kevin
16 Jul 2020 17:21 #174869
by kevin
Linuxcnc questions was created by kevin
Hi everybody
After install linux cnc 2.7.14, there are some question need help.
1/ when i shutting down my computer, display show black color with '' shutdown'', and need to press hard button one more time to complete the shutting down. I don't know what is problem, pls help to fix it.
2/ Mouse difficult to move after 10 minutes sleep, it looks like lag in my pc
3/ When i connect 1 more MPG on 2nd parallel card, the first time it works, but after shutting down my pc, it not works.
it looks like missing parallel address
after restepconf a gain, and readdress the parallel port, it works again.
I don't know what is problem know, i take 1 weeks to find it but no result,
Pls help to advise.
Kevin
Pls help to advise.
Kevin
- Thank you received: 7468
16 Jul 2020 17:56 #174870
Replied by tommylight on topic Linuxcnc questions
1. ACPI is switched off in BIOS.
2. very low memory, add more.
3. In BIOS there is a setting for automatically assigning IRQ to cards, set that to manual.
Time to create page: 0.082 seconds
