gEDA
6 years 3 months ago #174961 by gbbickerton
gEDA was created by gbbickerton
Has anyone been able to install gEDA in stretch it is listed in the package manager but is not available to install.
6 years 3 months ago #174964 by tommylight
Replied by tommylight on topic gEDA
Try enabling the "partner" repositories in the "software sources"
6 years 3 months ago #175056 by gbbickerton
Replied by gbbickerton on topic gEDA
I have had a search around and as far as I can tell that would be an option in the Ubuntu version there seems to be no similar thing in Debian stretch.
6 years 3 months ago #175063 by tommylight
There must be one, what De are you using?
XFCE has one for sure, Mate also, under the administration menu.
6 years 3 months ago #175070 by gbbickerton
I have xfce 4.12 I only have an applications menu which has a settings and a system entry but there is no software sources option.
6 years 3 months ago #175071 by tommylight
Try this in a terminal:
sudo apt-get install synaptics
That should also add the sources stuff, so open synaptics, in the settings menu there should be "repositories", enable "unstable packages"
Time to create page: 0.304 seconds
