Quickly modifying only MB2HAL?
- RetrofitTools
17 Jul 2020 21:19 #174967
by RetrofitTools
Quickly modifying only MB2HAL? was created by RetrofitTools
Could someone point me in the right direction to quickly change MB2HAL?
I need to change:
github: linuxcnc/src/hal/user_comps/mb2hal/mb2hal.h
so the functions can handle more than 100 I/O points, which is the current limit hardcoded in the header.
[Which is incidentally a pretty small limit for discrete i/o!]
Is there a way I can rebuild just mb2hal and not mess with figuring out the entire linuxcnc build process? I'd prefer to keep working on the I/O and not get sidetracked enormously...
Thank you!
I need to change:
Thank you!
- phillc54
- Thank you received: 2100
17 Jul 2020 23:19 #174975
by phillc54
Replied by phillc54 on topic Quickly modifying only MB2HAL?
Time to create page: 0.107 seconds
