switch field power on a 7i76
- bevins
- Thank you received: 338
25 Jul 2020 17:22 #175758
by bevins
switch field power on a 7i76 was created by bevins
Did I remember Peter saying do not put a switch on field power?
There is a switch to turn on dc power 24vdc. Is it advisable not to use this switched 24vdc for field power on a 7i76?
I thought I remember Peter saying not to do that. IS this true?
- Thank you received: 5321
25 Jul 2020 17:24 #175760
Replied by PCW on topic switch field power on a 7i76
Yes you should switch the primary power not the DC
Note that this is true of most DC powered devices
- bevins
25 Jul 2020 17:26 #175761
by bevins
OK so this chineese router is switching 24vdc side of a power supply. This would require \rewiring the machine. IS it a DONT DO or a probably shouldnt do thing?
Replied by bevins on topic switch field power on a 7i76
25 Jul 2020 17:32 #175763
Its really a "don't do" on most DC electronics as there is nothing to
limit the surge current other than wiring inductance when the load
(and its bypass capacitors) is instantly connected to the power supply
- bevins
25 Jul 2020 17:40 - 25 Jul 2020 17:41 #175767
by bevins
OK, thanks....
IT is switching 24vdc to everything except the drives which get 24vdc whenever the machine is powered on. There is an on/off switvh that turns on 24vdc to the rest of the machine. Do the drives normally need 24vdc all the time or better yet would it hurt if I switched that 24vdc also? Yaskawa servo[pack SGD7S
Actually I think I am just going to add a din rail 24vdc power supply for the field power, and switch relays that will send the other 24vdc though to the devices that need them.
/EDIT that way I could switch my 5 vdc power supply also instead of it being on all the time.
OK, thanks....
Last edit: 25 Jul 2020 17:41 by bevins.
Time to create page: 0.116 seconds
