- LinuxCNC
- General LinuxCNC Questions
- button toggle output then also motion digital out on same output with or functio
- bevins
- Thank you received: 338
30 Jul 2020 22:18 #176568
by bevins
button toggle output then also motion digital out on same output with or functio was created by bevins
Here is what I am trying to do.
Dust shoe needs to be controlled by button but the toolchange needs to to control it also.
the button must toggle it up, push button again then it goes down. That;s working by itself.
I need to have that output controlled by motion-digital-output also.
I tried running button through toggle function then feed to one leg of the or function. that doesn't work.
the toggle functions working and if I do the or function without toggle it is working but I can't get the output of
the toggle to feed the or and if I do would setting the motion digital out reset the toggle?
- Thank you received: 7468
30 Jul 2020 22:37 #176571
Replied by tommylight on topic button toggle output then also motion digital out on same output with or functio
There should be pins like
prepare-tool
and
tool-is-changed
i am pretty sure i have seen something like that in LinuxCNC, so those would be your best bet.
Found it:linuxcnc.org/docs/html/man/man1/iocontrol.1.html
prepare-tool
and
tool-is-changed
Found it:
iocontrol.0.tool−change
(Bit, Out) TRUE when a tool change is requested
iocontrol.0.tool−changed
(Bit, In) Should be driven TRUE when a tool change is completed.Please Log in or Create an account to join the conversation.
- bevins
30 Jul 2020 22:57 #176575
by bevins
That's not what I am looking for. I am trying hal logic so I can toggle the dust shoe with a button and also the remap needs to raise the dust shoe.
Replied by bevins on topic button toggle output then also motion digital out on same output with or functio
prepare-tool
and
tool-is-changed
Found it:linuxcnc.org/docs/html/man/man1/iocontrol.1.htmliocontrol.0.tool−change (Bit, Out) TRUE when a tool change is requested iocontrol.0.tool−changed (Bit, In) Should be driven TRUE when a tool change is completed.
- bevins
30 Jul 2020 23:02 - 30 Jul 2020 23:09 #176576
by bevins
The code below is working except I need a button to toggle the first input to the or function.
instead of hm2_7i92.0.7i76.0.0.input-08 in the first leg of the or function I need that to be output of a toggle function.
like so, except it don't work.
#BRUSH HOUSING
net brush_housing_up-A hm2_7i92.0.7i76.0.0.input-08 or2.0.in0
net brush_housing_up-B motion.digital-out-01 or2.0.in1
net brush_housing or2.0.out => hm2_7i92.0.7i76.0.0.output-10instead of hm2_7i92.0.7i76.0.0.input-08 in the first leg of the or function I need that to be output of a toggle function.
#DUST COLLECTOR SHOE
net stops-in toggle.0.in <= hm2_7i92.0.7i76.0.0.input-16
net brush_housing_up-A toggle.0.out or2.1.in0
net brush_housing_up-B motion.digital-out-02 or2.1.in1
net brush_housing_up or2.1.out hm2_7i92.0.7i76.0.0.output-09
Last edit: 30 Jul 2020 23:09 by bevins.
- bevins
30 Jul 2020 23:20 #176579
by bevins
I got it to work except I don't know what motion-digital-out on the second leg will do to the toggle. If I set the digital out for that output will the toggle be set back?
- Thank you received: 4144
31 Jul 2020 07:59 #176611
Replied by rodw on topic button toggle output then also motion digital out on same output with or functio
Bevins, You'll be happy about this solution becasue you will get to do some coding in your beloved Python!
I don't know about tool changers but if you send digital pins (analog or digital) to a pin in your screen handler, you can add a python handler for the pin to change the value of the screen variable tat you change from the GUI. islander261 and I did this ages ago pre-plasmac and I think there might be some examples in the plasma section near the last page somewhere.
- bevins
01 Aug 2020 12:33 #176773
by bevins
I am going to do it with hardware. I am tired of this software kicking my ass.....
01 Aug 2020 13:21 #176778
Wrong topic !
Will try to move it where it belongs.
- LinuxCNC
Time to create page: 0.342 seconds
