( Solved ) Issues with python plugin for remap
02 Aug 2020 17:04 #176908 by tommylight
Replied by tommylight on topic ( Solved ) Issues with python plugin for remap
If you mean that green space thingy, that is the active offsets.
For the rest i have no clue.
  • bevins
  • bevins's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Aug 2020 12:28 #177034 by bevins
Any thoughts on this? I am stuck with a machine that wont change tools and I don't know why.
Anyone else have this issue lately?
03 Aug 2020 14:27 #177044 by tommylight
Sorry, i just recall having issues with some analogue values several years back, and have not used changers since.
  • bevins
  • Platinum Member
  • Platinum Member
03 Aug 2020 15:37 #177049 by bevins
Until someone responds, I am loading linuxmint and am going to run 2.8 see if anything changes.
  • bevins
  • Platinum Member
  • Platinum Member
03 Aug 2020 18:14 - 03 Aug 2020 18:21 #177064 by bevins
new box 2.8 same thing. I am out of options with linuxcnc......
I dont know what else to do.
Maybe try a different distribution than linux Mint.
Last edit: 03 Aug 2020 18:21 by bevins.
03 Aug 2020 20:37 #177087 by cmorley
distribution change is the least likely cause.
can you confirm the sample sim/axis/remap/extend-builtin works?
I then added print statements to nc_files/remap_lib/stdglue.py 's
change_prolog and change_epilog.
They both printed when I ran the default program for that sample from 2.8
This would prove the underlying code is working.
The following user(s) said Thank You: bevins, tommylight
  • bevins
  • Platinum Member
  • Platinum Member
03 Aug 2020 21:22 #177103 by bevins
I will check this tonight, but did you run this on machine or simulator?
03 Aug 2020 22:02 #177112 by cmorley
sim
  • bevins
  • Platinum Member
  • Platinum Member
03 Aug 2020 23:05 #177121 by bevins
Rack_tool change and extend-builtin works in the sim.
  • bevins
  • Platinum Member
  • Platinum Member
03 Aug 2020 23:13 #177123 by bevins
not sure how to make the sim config work on a real machine. IT has the halib,
Time to create page: 0.139 seconds
