Which Mesa board?
6 years 2 months ago #177142 by PCW
Replied by PCW on topic Which Mesa board?
Unfortunately the 7I76ED only changes the digital outputs
to sinking vs the 7I76Es sourcing output drivers.
The inputs are still sinking and require sourcing drivers
(switches, PNP sensors etc)
A 7I95,7I96, 7I97, 7C80 can use sourcing or sinking drivers
for their inputs. a 7I76E or 7I76ED would need pullup resistors
to interface with sinking (NPN type) sensors.
The following user(s) said Thank You: bevins, Clive S
6 years 2 months ago - 6 years 2 months ago #177148 by palmac
Replied by palmac on topic Which Mesa board?
Oh now I'm confused :(
My servo drives are fairly new Chinese drives, step and direction for DC servo motors. My sensors are all NPN. Im currently running Mach4 with Ethernet smooth stepper and BOB. I want to gut all this for Linuxcnc and and use the 7i76e in place of both the ESS and the current 5v BOB.
So with all this in mind is it the 7i76e or ed? I dont mind changing stuff around.
So its looking more like the regular 7i76e and then using pull-up resistors to accommodate all my NPN limit / homing switch inputs. Yes?
Last edit: 6 years 2 months ago by palmac.
6 years 2 months ago #177150 by bevins
Replied by bevins on topic Which Mesa board?
PCW wrote: Unfortunately the 7I76ED only changes the digital outputs
Wow, I didnt know that. I thought it swapped the inputs also. Thanks.
6 years 2 months ago #177189 by Clive S
Replied by Clive S on topic Which Mesa board?
palmac wrote: Oh now I'm confused :(
Yes , that is what I would do. With the 7i76 or 7i76e you can also fit two mpg's on it as well :)
The following user(s) said Thank You: palmac
6 years 2 months ago - 6 years 2 months ago #177198 by rodw
Replied by rodw on topic Which Mesa board?
I would go with the 7i76e if you don't gain anything to help with the inputs. When I built my machine, I bought all these NPN sensors and then found out I should have used PNP's's I just added the pullups and it all works pefectly.
Last edit: 6 years 2 months ago by rodw.
6 years 2 months ago #177199 by Clive S
rodw wrote: I would go with the 7i76e if you don't gain anything to help with the inputs. When I built my machine, I bought all these NPN sensors and then found out I should have used NPN's I just added the pullups and it all works pefectly.
Did you mean PNP
