TraJ defaul_linear_accelleration ans max_linear_accelleration
- papagno-source
- Thank you received: 13
03 Aug 2020 19:23 #177071
by papagno-source
TraJ defaul_linear_accelleration ans max_linear_accelleration was created by papagno-source
Hi .
I have test in real machine and simulation axis the value in .ini file section TraJ
the defaul_linear_acceleration and max_linear_accelleration non fuction.
I use master 2.9-pre0 actual master branch.
For limit or increase the real accelleration is only max_accelleration in section AXIS.X and Joint.x.
I have test change the same value in hal : ini.traj.defaul_accelation and ini.traj.max_accelleration.
It not have effect on real accelleration.
Example impose ini.x.max_accelleration = 1000 and ini.traj.max accelleration = 1 and ini.traj.default_acceleration =1 .
the machine running with acceleration the 1000 , traj section not is respected.
The defaul accelleration is good normally have a more small value for jog operation, but not is resepcted.
because
thanks
because
thanks
- Thank you received: 7468
03 Aug 2020 19:31 #177073
Replied by tommylight on topic TraJ defaul_linear_accelleration ans max_linear_accelleration
Did you try to run some gcode with those settings ?
The TRAJ section is for the trajectory planner so it should have no effect while jogging, as far as i know.
- papagno-source
04 Aug 2020 11:45 - 04 Aug 2020 11:51 #177218
by papagno-source
Replied by papagno-source on topic TraJ defaul_linear_accelleration ans max_linear_accelleration
The alway gcode type g0 x100 respect only acceleration declared in file .ini section AXIS.X : max_accelleration and section Joint.0 max accelleration.
what is fuction the section TraJ : max_linear accelleration ?
In jog mode and ref mode the axis move always in file .ini section AXIS.X : max_accelleration and section Joint.0 max accelleration.
The traj section not have fuction.
Please test in sim axis .
change .ini file
Traj section :
max_linear_accelleration 0.01
move in jog or in mdi always axis and it will move with acceleration declared
in in file .ini section AXIS.X : max_accelleration and section Joint.0 max accelleration.
what is the fuction acceleration in Traj if not change accelleration ?
change .ini file
Traj section :
Last edit: 04 Aug 2020 11:51 by papagno-source.
04 Aug 2020 12:57 #177238
TRAJ section should be respected when running actual gcode.
Time to create page: 0.106 seconds
