Total Machine time
21 Aug 2020 14:52 #178924 by Mike_Eitel
Replied by Mike_Eitel on topic Total Machine time
If it works (i saw your youtube) that is good enough. Congrats.
I'm a bit concerned that shelly does not make possible to use encription if you do not use their cloud solution. I totaly dislike such 'forced remote in'.
Mike
  • anfänger
  • anfänger's Avatar Topic Author
  • Platinum Member
  • Platinum Member
21 Aug 2020 16:42 - 21 Aug 2020 16:46 #178937 by anfänger
Replied by anfänger on topic Total Machine time
None of my Shellys are in the cloud. I don’t see the point in my network I think you can use passwords but I didn’t check for https. If someone brakes intime network the Shellys are the least of my concerns
Last edit: 21 Aug 2020 16:46 by anfänger.
10 Jan 2023 15:49 - 10 Jan 2023 15:50 #261455 by kang2k
Replied by kang2k on topic Total Machine time
Please help
How starting timer ?
In postgui.hal i write
loadusr totaltime.py -Wn
Last edit: 10 Jan 2023 15:50 by kang2k.
11 Jan 2023 00:25 #261515 by andypugh
Replied by andypugh on topic Total Machine time
In HAL connect the totaltime.active pin to something like spindle.0.on to log total spindle time.
11 Jan 2023 06:46 #261540 by kang2k
Thanks, or connect to halui.program.is-runing pin. And loadusr in the main hal.!
Time to create page: 0.205 seconds
