Large files
- dpedreira
13 Aug 2020 06:35 #178067
by dpedreira
Large files was created by dpedreira
Hi everyone. I'm new to the CNC community. I'm using LinuxCNC 2.6. I am having issues loading large files. I have to divide a large finish file into 2, 3 or 4 smaller files and load them individually. This creates a Z axis problem because you can see where a file stops and starts, it basically destroys the piece. Which version can handle larger file and what's the minimum recommended RAM and SSD gigabit sizes. I appreciate anyone's input. Thank you
- Thank you received: 7468
13 Aug 2020 06:58 #178070
Replied by tommylight on topic Large files
How large are we talking about ?
I often used over 4MB files without any issues on some old laptops.
You can try upgrading to 2.7 and see if that changes things, or if you're felling lucky go to 2.8 but beware that 2.8 has a lot of changes from 2.6 and 2.7, so if you are using any special comp you might need to recompile. For standard configs, there is a wizard that takes care of the changes automatically .
- dpedreira
13 Aug 2020 11:46 #178094
by dpedreira
Replied by dpedreira on topic Large files
This is going to sound odd but I'm not sure how big the files are. What I do know is that I can only go up to about 1 million lines of code. I'm told by Len at probotix that the files size is not the issue, the issue is the several million lines of code. This stuff does not make sense to me. What size RAM and SSD do you have? Also, can I reduce the lines of code and still accomplish the same result? Im trying to do the "Last Supper" all my attempts have resulted in having to load several files on the finish pass. Can you please help me understand all of this better?
13 Aug 2020 14:10 #178101
Are you trying to do a depth map ? Meaning a picture with different depths with the machine moving from side to side ?
Give dmap2gcode a try, it did work very nicely for me.
www.scorchworks.com/Dmap2gcode/dmap2gcode.html
- dpedreira
13 Aug 2020 15:55 - 13 Aug 2020 15:59 #178111
by dpedreira
I'd like to send some pictures of the issue I'm having so you can see what I'm trying to do. The pictures are too large to send on here, may I email you?
Last edit: 13 Aug 2020 15:59 by tommylight. Reason: Removed e-mail to protect from spammers
13 Aug 2020 15:59 #178112
Use GIMP to scale them, it is included with most Linux distros, or install it by running this in a terminal
sudo apt-get install gimpPlease Log in or Create an account to join the conversation.
- dpedreira
13 Aug 2020 16:07 #178113
by dpedreira
I see my email address did not go thru. It's my user name at Yahoo.com
13 Aug 2020 16:27 #178114
I deleted it, it is not prudent to post e-mail addresses on public boards, it will get you plenty of spam.I see my email address did not go thru.
- dpedreira
13 Aug 2020 16:29 #178115
by dpedreira
I understand, thank you. I will try to reduce the picture size so you can see it.
- dpedreira
Time to create page: 0.339 seconds
