Installing on Raspbian 10
14 Aug 2020 15:19 #178191 by kramerda
Installing on Raspbian 10 was created by kramerda
Followed Section 3.7.3 Installing on Rasbian 10 of Getting Started Guide 2.9............................8-14
At step 6 sudo apt-get install linux-image-4..19.71-rt24-v71+
Error messages - "unable to locate package linux-image.............................
Couldn't find any package by glob
Couldn't find any package by regex
Is there a newer (or older) image that I should be using....................????
Thankyou for any guidance here.
14 Aug 2020 23:45 #178215 by phillc54
Replied by phillc54 on topic Installing on Raspbian 10
15 Aug 2020 00:50 #178218 by kramerda
Replied by kramerda on topic Installing on Raspbian 10
Thanks Phil for taking the time to answer. I fixed some syntax errors (L vs l vs 1) and started with Rasbian Lite this time. That allowed me to get to the last step after installing the kernel. When I rebooted (so I could install linuxcnc-uspace) it just came up with a square four color screen - filling the monitor. No keyboard, mouse or termnial - all locked out. May have lost internet during last download - will try again.
Since its locked up now - Im guessing I have to start from scratch with a fresh Raspbian 10 image on a clean SD. Will try tomorrow. Thanks, Dennis
15 Aug 2020 01:00 #178219 by phillc54
Once you have raspbian installed you could download that deb to your Downloads directory and install with:
sudo apt install ~/Downloads/linux-image-4.19.71-rt24-v7l+_4.19.71-rt24-v7l+-4_armhf.deb
15 Aug 2020 19:48 #178318 by kramerda
OK - reinstalled everything - including step 6 for the kernel. Heres the screen shot following that image install - not sure if these errors are significant (OK to install linuxcnc -uspace) or fix somthing first. So sorry for crappy jpg.
16 Aug 2020 00:19 - 16 Aug 2020 05:51 #178337 by phillc54
This may be worth a try:
forum.linuxcnc.org/9-installing-linuxcnc...-bit-linuxcnc#178299
Edit: I tried this today and it does work well.
Last edit: 16 Aug 2020 05:51 by phillc54.
17 Aug 2020 12:56 #178477 by kramerda
Thankyou --- we'll give it a try - encouraging that you verified the process.
17 Aug 2020 13:04 #178479 by kramerda
Any reason to not just download the kernel (rt64-kernel.tgz) ready for install - skipping steps 1-5 of the 'Instructables' process.
For a newbie seems like the way to go.
Or is patching and compiling still necessary ?
17 Aug 2020 15:32 #178481 by andypugh
Replied by andypugh on topic Installing on Raspbian 10
There seems to be a problem over-writing some special Raspbian files.
Jepler on IRC found an inelegant solution:
jepler: andypugh: last time I suggested that this command let me
complete an upgrade from one version of my kernel to another:
dpkg-divert --list | grep rpikernelhack | while read _ _ a _ _ _ _;
do dpkg-divert --package rpikernelhack --no-rename --remove $a; done
[02:35am] jepler: and said it appeared that something could leave the
diverts around but I have not discovered what does that besides
interrupting a package installation.
[02:36am] jepler: after running that command, re-run the installation
of the new kernel
[02:36am] jepler: as root
17 Aug 2020 23:04 #178548 by phillc54
That was the way I did it.
Time to create page: 0.269 seconds
