Installing on Raspbian 10
- Thank you received: 4652
18 Aug 2020 08:33 #178578
Replied by andypugh on topic Installing on Raspbian 10
Does that kernel work "better" than the LinuxCNC-produced version of the kernel?
The "official" way to install LinuxCNC on the Pi is described in the LinuxCNC docs, but if that does not work that means I have further work to do.
linuxcnc.org/docs/2.8/html/getting-start...lling_on_raspbian_10
- phillc54
- Thank you received: 2100
18 Aug 2020 08:56 #178579
by phillc54
Replied by phillc54 on topic Installing on Raspbian 10
The jury is still out, I hope to do a machine test tomorrow or Thursday.
For 2.8 it is probably best to stick with what you have now as the buildbot rpi builds are 32 bit.
23 Aug 2020 00:32 #179053
I am finding that this is not as simple as I hoped.
While asking the chap who built the kernel for help, he seemed puzzled that I wasn't using his pre-built SD card images (because I didn't know they existed)
zaphod.unpythonic.net/pi/
preempt and linuxcnc on an image, all ready to go.
- Thank you received: 7468
23 Aug 2020 06:35 #179068
Replied by tommylight on topic Installing on Raspbian 10
Should i make a topic about it and make it sticky ?zaphod.unpythonic.net/pi/
23 Aug 2020 10:46 #179090
Probably not yet, the plan is to set it up with 2.8 and serve it from www.linuxcnc.org
23 Aug 2020 19:58 - 23 Aug 2020 19:58 #179134
That image is set up with a default "linuxcnc" username.
Part of the message is hidden for the guests. Please log in or register to see it.
Last edit: 23 Aug 2020 19:58 by andypugh.
Time to create page: 0.087 seconds
