- LinuxCNC
- General LinuxCNC Questions
- Stepper motors trip power supply only when run through linux cnc
- M Sills
20 Aug 2020 06:12 #178799
by M Sills
Replied by M Sills on topic Stepper motors trip power supply only when run through linux cnc
I added a 12,000uf capacitor to my power supply and everything seems to be working properly.
I'll test is a good bit tommorow to make sure every thing is fine.
I'll update again when I am done testing.
- Thank you received: 7468
20 Aug 2020 13:08 #178824
Replied by tommylight on topic Stepper motors trip power supply only when run through linux cnc
Nice, that should work.
- M Sills
22 Aug 2020 01:22 - 22 Aug 2020 01:23 #178971
by M Sills
Yesterday, my pi stopped working randomly. While I wait for a new one, I am testing my main desktop in a dual boot set up.
As an update to if the capacitors fixed the issue, well... I can't replicate the problem using my desktop for linuxcnc. I am using the same config file, the same power supplies and not using the capacitors and I cannot replicate my issue. I have higher accelerations and higher speeds.
The issue existed across multiple pi images with multiple versions of linuxcnc. Either I set it up wrong multiple times which is entirely possible or something was wrong with my pi.
When my replacement pi comes in, I'll run the same SD card and see if it happens again. I'll try to update if I remember to.
Thanks for the help.
Last edit: 22 Aug 2020 01:23 by M Sills. Reason: Always find the typos after I post.
- Mike_Eitel
- Thank you received: 183
22 Aug 2020 05:05 #178976
by Mike_Eitel
Replied by Mike_Eitel on topic Stepper motors trip power supply only when run through linux cnc
With a "hardend" power source you also prevent emv spikes.
A pi is nice, but as fare as i know it's not proven to be on "industrial niveau". You can buy such versions, but not for low money.
F.x:
www.hilscher.com/de/produkte/produktgrup...edge/niot-e-npi3-en/
Mike
F.x:
Mike
22 Aug 2020 20:53 #179034
All that points to a wiring issue, so double check the wiring before using the new RPI as it might follow in the foot steps of it's predecessors !Yesterday, my pi stopped working randomly.
- LinuxCNC
Time to create page: 0.096 seconds
