I have a 5 axis MVJR Mori Seiki that is retrofitted with LINUX CNC.
Most things are working except the B rotary axis has an issue. It moves as expected.
But, if the machine is on, just sitting there the B axis will occasionally jump a short distance.
If I turn the servos off for a long time (several days) but leave LINUX CNC on, and then Turn the servos on, the B axis will violently jump a long way about 20 degrees.
My guess is that something is wrong with the encoder or wiring that is falsely signalling that the axis has moved.
Does anyone have any ideas for other things that could cause this?
Or how to diagnose the source?
I am thinking of maybe getting an analog continuity tester and testing the connections to the rotary axis encoder.
