G54 Loses Settings
- satiowadahc
- Thank you received: 12
18 Aug 2020 21:32 #178633
by satiowadahc
G54 Loses Settings was created by satiowadahc
Hi All,
Having an odd issue where switching from G54->G55->G54, Sometimes (Not always) overwrites G54 Coordinates with G55 Coordinates.
EG,
(Homed and at 0)
MDI:
G0 X10Y10
G54
G10 L20 P0 X0
(Run Program, Say 10x10 Square. Its not unique to any code, End at X10Y0)
G55 (or G56 etc.)
G10 L20 P0 X0
G54
G54 in the var file is sometimes now overwritten by either the difference between the two systems, or the second coordinate system.
Currently running lcnc 2.8 with custom interface.
EG,
(Homed and at 0)
MDI:
G0 X10Y10
G54
G10 L20 P0 X0
G55 (or G56 etc.)
G10 L20 P0 X0
G54
- Thank you received: 2175
19 Aug 2020 06:21 #178678
Replied by cmorley on topic G54 Loses Settings
as a test, try setting the P value in the G10 line to the actual user system number.
eg p1=g54 etc.
Chris
eg p1=g54 etc.
Chris
- satiowadahc
20 Aug 2020 13:54 - 20 Aug 2020 13:58 #178830
by satiowadahc
Replied by satiowadahc on topic G54 Loses Settings
So interesting, its seems using the axis P1-9 instead of 9 doesn't recreate the issue, can let the machinists work while I diagnose now
However on P0-9 it doesn't seem to update the var file until after start is pressed. Might need to dive into this a little more now. Do you know what function or file actually updates the var file?
Last edit: 20 Aug 2020 13:58 by satiowadahc. Reason: *Edit: Clarity
Time to create page: 0.105 seconds
