Need advice with analog servodrives
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
23 Aug 2020 15:23 - 23 Aug 2020 15:40 #179108 by aleksamc
Need advice with analog servodrives was created by aleksamc
I want to refit cnc machine with analog servodrives (-10 .. +10V analog input and pnp discreat inputs)
I choused such devices of MESA to buy:
7i77 and 5i25.
Mother board has 1pcs of PCIE16x and 2 pcs of PCIE1x free.
Does 5i25 supports PCIE1X if not then PCIE16X?
In the magazine:
1) What does mean "PCI/PCIe mounting bracket type - (REQUIRED OPTION: SELECT TYPE)"
- Standard profile
- Low profile?
Machine has no gears on servodrives. It's very fast.
I think it will work maximum on 1,5V of task voltage to reach needed speed.
I know that analog drives works bed at low speeds.
How to increese precision of coordinates movement at low speeds?
I think that to set gears 1:15 is best but expensive idea, I will not chouse it.
If I set between servodrive and control board operational aplifier to reduce working load for example, I change 10V to 2V. Will it be better?
Or is it possible to use 5i25 not with 10V but with other voltage?
Last edit: 23 Aug 2020 15:40 by aleksamc.
  • Moderator
  • Moderator
23 Aug 2020 15:56 #179112 by tommylight
Replied by tommylight on topic Need advice with analog servodrives
You need a 6i25 for PCI-E and you can use any of the slots, it will work properly, it does not matter if it is X1 or X4 or X16
  • aleksamc
  • Platinum Member
  • Platinum Member
23 Aug 2020 21:46 #179147 by aleksamc
Replied by aleksamc on topic Need advice with analog servodrives
Thanks for that, Tommylight.
And what about precision of low speed motion?
How do you think, it will work fine for carving relief, for example?
  • Moderator
  • Moderator
24 Aug 2020 11:47 #179230 by tommylight
If the servos are tuned correctly, it should work, but that all depends on how much power the servos have, what are the cutting forces, what is the distance the machine goes for one turn of the servos, etc.
  • aleksamc
  • Platinum Member
  • Platinum Member
24 Aug 2020 19:22 #179267 by aleksamc
OK, thanks. I will try standart wiring.
