run form here don't work
- RobotMatic
- Thank you received: 25
23 Aug 2020 23:53 #179164
by RobotMatic
run form here don't work was created by RobotMatic
I wanted to leave the comment that I had problems with the function { run form here ], I am with linuxcnc 2.7.15 in lathe mode.
it happens that it reads the code but does not execute it, the machine is stopped.
- Thank you received: 2175
24 Aug 2020 04:04 #179184
Replied by cmorley on topic run form here don't work
What screen are you using?
What whee you expecting to happen that didn't happen?
- RobotMatic
27 Aug 2020 01:37 #179619
by RobotMatic
Replied by RobotMatic on topic run form here don't work
Hi. Sorry for my late reply.
I am using axis in 2.7.15
select the line from where I wanted to run my program. It happened that linuxcnc read but did not execute.
run from here don't work
27 Aug 2020 03:05 #179635
Can you post a program that shows the problem?
Do you use remapped Gcodes or anything exotic like that?
Can you test a simulated configuration to see if it behaves the same?
- RobotMatic
28 Aug 2020 01:28 #179770
by RobotMatic
Hi. Yes!!. I can do all that, I only need to retrieve the program that is on a machine that belongs to a client. I will post again when I have it.
Time to create page: 0.071 seconds
