Wheezy + RDP
25 Aug 2020 21:05 #179451 by Asher
Wheezy + RDP was created by Asher
Hello, help me, I am not good at Linux
I installed Debian 7 Wheezy and configured RDP on it, but when connected via RDP, LinuxCNC does not start
First error:
RTAPI: ERROR: failed to map shmem
RTAPI: Locked memory limit is 64KiB, recommended at least 20480KiB.
This can cause the error 'failed to map shmem'.
For more information, see
wiki.linuxcnc.org/cgi-bin/emcinf ... ckedMemory
HAL: ERROR: could not open shared memory
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
i try fix it
operator1@debian:~$ ulimit -l
64
operator1@debian:~$ sudo /bin/bash
[sudo] password for operator1:
root@debian:/home/operator1# su operator1
20480
operator1@debian:~$ linuxcnc /home/operator1/linuxcnc/configs/st/st.ini
LINUXCNC - 2.7.15
Machine configuration directory is '/home/operator1/linuxcnc/configs/st'
Machine configuration file is 'st.ini'
Starting LinuxCNC...
Found file(REL): ./st.hal
Found file(REL): ./custom.hal
waiting for s.axes
waiting for s.axes
waiting for s.axes
waiting for s.axes
RTAPI: ERROR: Unexpected realtime delay on task 1
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
waiting for s.axes
Exception in Tkinter callback
  File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1437, in __call__
    return self.func(*args)
  File "/usr/bin/axis", line 1325, in jogspeed_listbox_change
    if isinstance(value, str): value = value.encode('utf-8', 'replace')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xd0 in position 0: ordinal not in range(128)
X Error of failed request:  BadWindow (invalid Window parameter)
  Major opcode of failed request:  3 (X_GetWindowAttributes)
  Resource id in failed request:  0xffffffff
  Serial number of failed request:  653
  Current serial number in output stream:  654
task: 32 cycles, min=0.000004, max=0.066255, avg=0.013887, 0 latency excursions (> 10x expected cycle time of 0.010000s)
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/operator1/linuxcnc_debug.txt
and
    /home/operator1/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
operator1@debian:~$
graphics and display settings also don't start
operator1@debian:~$ glxgears
Error: couldn't get an RGB, Double-buffered visual
operator1@debian:~$ glxinfo
name of display: :10.0
Error: couldn't find RGB GLX visual or fbconfig
  • Moderator
  • Moderator
26 Aug 2020 11:50 #179519 by tommylight
Replied by tommylight on topic Wheezy + RDP
VNC should work, although it was several years ago that i tested it.
www.google.com/search?source=hp&ei=h0xGX...IzA18Q4dUDCAY&uact=5
26 Aug 2020 17:56 #179560 by Mike_Eitel
Replied by Mike_Eitel on topic Wheezy + RDP
Not sure if i ever did in wheezy.
Did you mean xrdp.. And have you googled what to do?
Mike
26 Aug 2020 19:46 #179569 by Asher
Replied by Asher on topic Wheezy + RDP
I tried TightVNC, also doesn't work
26 Aug 2020 19:53 #179572 by Asher
Mike
Yes, xrdp. I googled, but on russian. I find it difficult to search for information in English.
on Debian 9 Stretch it works, but there are other problems.
  • Moderator
  • Moderator
26 Aug 2020 20:33 #179578 by tommylight
Did you try to start LinuxCNC on the machine PC then connect to it ?
26 Aug 2020 20:57 #179584 by Asher
when connecting via RDP, a new session is opened
27 Aug 2020 07:36 #179668 by Mike_Eitel
Yes. That is normal. But you must not be already logged in with the same user on the machine. That is different from windows.
27 Aug 2020 08:49 #179671 by Asher
Done. I have installed:
sudo apt-get install libgl1-mesa-swx11
Time to create page: 0.124 seconds
