Real toolpath of tool is running next to toolpath from gcode file
  • Mara2000
  • Mara2000's Avatar Topic Author
  • Junior Member
  • Junior Member
27 Aug 2020 09:45 #179673 by Mara2000
Hi friends,
Could you help me to solv this issue? Machine real toolpath is running next to toolpaths generated from gcode file.
Please see atachment, include my setting.
Thank you :-)
27 Aug 2020 12:00 #179681 by Aciera
Have you tried resetting the tool path display by clicking on the brush symbol in the lower right corner?
27 Aug 2020 13:41 #179686 by MaHa
This may happen, if you change working offset unpredictable after program start, eg. probing.
To avoid this, probe and set offset first in a separate operation, then run your ngc file.
  • Mara2000
  • Junior Member
  • Junior Member
27 Aug 2020 19:42 - 27 Aug 2020 19:46 #179730 by Mara2000
Thank you, yes it was change probing offset while probing. But so it seems that probing routine with probe screen not work correctly.
Last edit: 27 Aug 2020 19:46 by Mara2000.
  • Mara2000
  • Junior Member
  • Junior Member
27 Aug 2020 19:47 #179731 by Mara2000
Unfortunately without effect ... :-(
28 Aug 2020 00:40 #179763 by Grotius
I think you miss some of G90 startup code (reset) in your gcode file.
  • Mara2000
  • Junior Member
  • Junior Member
28 Aug 2020 17:45 #179858 by Mara2000
Ok, thank you, i try to set it in fusion 360 posprocessor. :-)
Time to create page: 0.396 seconds
