Spindle speed control P/port
- Clive S
- Thank you received: 486
27 Aug 2020 17:12 #179706
by Clive S
Spindle speed control P/port was created by Clive S
Chinese bob blue relay. Problem on switch on the 0-10 volt from the BOB is at around 10V so starting the spindle with m3 the spindle is at full speed.
On the Axis gui in manual on the spindle control the + arrow make the spindle slower and the - faster.
Should the 0-10v be low on switch on? if so can I just change the pwm scale to -
- Thank you received: 7468
27 Aug 2020 21:03 #179741
Replied by tommylight on topic Spindle speed control P/port
Setting the PWM pin to inverted should fix that, in hal.
setp parport.0.pin-04-out-invert TRUE
Chang the pin number.
- Clive S
28 Aug 2020 15:34 #179850
by Clive S
That solved it. I also had to calibrate it using this :-
linuxcnc.org/docs/2.8/html/config/stepco..._spindle_calibration
Replied by Clive S on topic Spindle speed control P/port
