jump to a block number
- RobotMatic
- Thank you received: 25
28 Aug 2020 01:39 #179773
by RobotMatic
jump to a block number was created by RobotMatic
I would like to ask you if there is any way to jump to a certain block number.in Fanuc it is M99 P_ where P indicates the block number to execute.
it would be like a Go To in Basic.
I have not been able to do it within my G code program.
I can only from [run form here] from outside the program
It is very important to be able to test programs and avoid blocks that I do not want to execute.
it's possible ?
thanks!!!
it's possible ?
thanks!!!
- Thank you received: 1480
28 Aug 2020 20:31 #179878
Replied by Todd Zuercher on topic jump to a block number
I don't think it is possible, at least not in that way.
The only work around I can think of is to break your file into a series of o-subprograms and call the o-sub you need.
- RobotMatic
30 Aug 2020 22:09 #180111
by RobotMatic
Replied by RobotMatic on topic jump to a block number
Yes, I thought the same, that's why I asked! In lathe mode, manual programming is used a lot and with long programs, it would be great to be able to jump in and test only the piece of code that I want. Currently I use it from the outside, but it is not working well for me, I already left another post on the subject. Regards.
Time to create page: 0.206 seconds
