Debating switching to linuxcnc
28 Aug 2020 06:19 #179786 by Birdman3131
Debating switching to linuxcnc was created by Birdman3131
So I recently picked up a Carvey that had been rewired to use Grbl on an arduino uno and a protoneer cnc shield. I may just keep it as is but I am debating switching to linuxcnc as I know its more powerful .... I'm just not sure I could take much advantage of that power.
So what would be the cheapest setup to get it working. Fairly sure I can get a free C2D or P4 machine from work if it will work for linuxcnc. They should still have a parallel port on them if I go that route.
As for stepper drivers I might be able to use the cncshield as it has separate power for the steppers but otherwise pulls all its signals as 5V signals from the arduino. If I did not go this route what would be the best cheap way to go? It would need to either accept the pololu style drivers I have already or have its own drivers.
I also plan to get this board to control the spindle speed. It is controlled by a 1k-10k frequency. (Getting it either way as I currently only have on or off but figured I would mention it if it mattered.)
I have kinda used linuxcnc before but only really setup a plasma cutter with it. So still solidly in the novice stage. And this one is for me not for work so is cheap china components the entire way. (Not sure I will ever make money off it but that is the dream.)
  • Moderator
  • Moderator
28 Aug 2020 11:20 #179813 by tommylight
Replied by tommylight on topic Debating switching to linuxcnc
Use it as is, i see no point in switching over for the time being, later you can save a bit and start building a bigger and more rigid machine then use LinuxCNC.
Time to create page: 0.192 seconds
