- LinuxCNC
- General LinuxCNC Questions
- Simulate/verify the HAL/INI configuration before connecting mesa board to drives
- shadab
- Thank you received: 4
31 Aug 2020 13:16 #180155
by shadab
Simulate/verify the HAL/INI configuration before connecting mesa board to drives was created by shadab
Hi all,
I have a 7i97 board, this board currently has very little support. I am making the configuration files by hand and before connecting the board to the drives I want simulate/verify the configuration. Is HalScope useful in this regard? What my intention is to maybe toggle a gpio or take a gpio input on the pins and verify whether the configuration works.
Thanks and Regards,
Shadab
Thanks and Regards,
Shadab
- Thank you received: 7468
31 Aug 2020 14:24 #180167
Replied by tommylight on topic Simulate/verify the HAL/INI configuration before connecting mesa board to drives
Mesa 7i97 is nearly the same as a 7i92 and a 7i77, so make a config for 7i92/7i77 and then replace the board name in the ini.
That should get you very close and there are some other minor changes i think but not sure since i do not have a 7i97, yet.
The following user(s) said Thank You: shadab
- Thank you received: 5321
31 Aug 2020 14:37 #180169
Replied by PCW on topic Simulate/verify the HAL/INI configuration before connecting mesa board to drives
I have provided a working skeleton hal/ini file for the 7I97 in another thread
- shadab
01 Sep 2020 05:53 #180256
by shadab
Replied by shadab on topic Simulate/verify the HAL/INI configuration before connecting mesa board to drives
Yes, thanks. I am using that file as a starting point.
- LinuxCNC
Time to create page: 0.354 seconds
