Hello Rodw.
Thank you for your time.I will follow your advice.I didn't want to tamper with the working system because I have CAN BUS in my configuration.It is not difficult to guess that it is reliable on Linuxcnc 2.8.
As you said, I solved my problem with siggen and offset component.Thanks for the quick response and correct guidance.
maybe I am writing the solution I obtained to set an example for others.
loadrt offset count=1
loadrt siggen num_chan=1
addf offset.0.update-output servo-thread
addf siggen.0.update servo-thread
setp siggen.0.amplitude 0.5
setp siggen.0.frequency 5
setp siggen.0.offset 0
net offset_sine siggen.0.sine offset.0.offset
#net offset_sine siggen.0.square offset.0.offset
net x_axis_cmd axis.0.motor-pos-cmd => offset.0.in
net x_axis_off_cmd offset.0.out => lcec.0.0.poscommand
net x_axis_fb lcec.0.0.pos => axis.0.motor-pos-fb
Thank you.
Best Regards...
