Using POSIX non-realtime but with PREEMPT RT
03 Sep 2020 15:07 #180554 by cnclover
Hello
I have a problem "Note: Using POSIX non-realtime" despite this Kernel 5.3.18-lp152.2-rt # 1 SMP PREEMPT_RT on Opensuse LEAP 15.2, can anyone kindly help me?
Thank you.
  • Moderator
  • Moderator
03 Sep 2020 16:46 #180561 by tommylight
Replied by tommylight on topic Using POSIX non-realtime but with PREEMPT RT
Try the 5.4 or 5.0 RT kernels, or 4.9.0 for better latency.
That warning means the kernel is not recognised as RT at all by the system.
04 Sep 2020 07:11 #180628 by cnclover
Replied by cnclover on topic Using POSIX non-realtime but with PREEMPT RT
Thanks you very much tommylight for your answer, I will try other Kernel versions as your advice.
