Cannot get example below from docs to work.
6 years 1 month ago #180571 by jeoslislo
If enabled in the INI file G-code has access to the values of INI file entries and HAL pins.
#<_ini[section]name> Returns the value of the corresponding item in the INI file. For example, if the ini file looks like so:
[SETUP]
XPOS = 3.145
YPOS = 2.718
you may refer to the named parameters #<_ini[setup]xpos> and #<_ini[setup]ypos> within G-code.
EXISTS can be used to test for presence of a given ini file variable:
o100 if [EXISTS[#<_ini[setup]xpos>]]
(debug, [setup]xpos exists: #<_ini[setup]xpos>)
o100 else
(debug, [setup]xpos does not exist)
o100 endif
All I get is setup]xpos does not exist.
I setup ini_vars:
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
INI_VARS = 1
Any ideas?
6 years 1 month ago #180577 by tommylight
Just a stab in the dark, but Linux does care about upper and lower case letters and they are not the same thing, so you might want to try and change that.
6 years 1 month ago #180581 by Todd Zuercher
What version of Linuxcnc are you running?
I'm not familiar with that feature, can you post a link to where it is documented?
My first guess is that it is probably case sensitive and will need to match the all caps used in the ini file.
6 years 1 month ago #180586 by Hakan
Isn't it the FEATURES that has to be set for _ini?
[RS274NGC]
FEATURES = 4
from the section above the given example in the docs.
6 years 1 month ago #180651 by jeoslislo
LinuxCNC/AXIS version 2.7.15
linuxcnc.org/docs/devel/html/gcode/overv...tml#gcode:parameters
4. HAL pins and INI values
From the docs:
The names are not case sensitive - they are converted to uppercase before consulting the ini file.
6 years 1 month ago #180653 by jeoslislo
It works with FEATURES = 4
I am running vers 2.7.15. Should I be using a later version? What is the easiest way to update?
