Cannot get example below from docs to work.
- jeoslislo
03 Sep 2020 19:20 #180571
by jeoslislo
Cannot get example below from docs to work. was created by jeoslislo
If enabled in the INI file G-code has access to the values of INI file entries and HAL pins.
#<_ini[section]name> Returns the value of the corresponding item in the INI file. For example, if the ini file looks like so:
[SETUP]
XPOS = 3.145
YPOS = 2.718
you may refer to the named parameters #<_ini[setup]xpos> and #<_ini[setup]ypos> within G-code.
EXISTS can be used to test for presence of a given ini file variable:
o100 if [EXISTS[#<_ini[setup]xpos>]]
(debug, [setup]xpos exists: #<_ini[setup]xpos>)
o100 else
(debug, [setup]xpos does not exist)
o100 endif
All I get is setup]xpos does not exist.
I setup ini_vars:
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
INI_VARS = 1
Any ideas?
[SETUP]
XPOS = 3.145
YPOS = 2.718
o100 else
o100 endif
I setup ini_vars:
[RS274NGC]
INI_VARS = 1
Any ideas?
- Thank you received: 7468
03 Sep 2020 20:26 #180577
Replied by tommylight on topic Cannot get example below from docs to work.
Just a stab in the dark, but Linux does care about upper and lower case letters and they are not the same thing, so you might want to try and change that.
- Thank you received: 1472
03 Sep 2020 20:31 #180581
Replied by Todd Zuercher on topic Cannot get example below from docs to work.
What version of Linuxcnc are you running?
I'm not familiar with that feature, can you post a link to where it is documented?
My first guess is that it is probably case sensitive and will need to match the all caps used in the ini file.
- Hakan
- Thank you received: 454
03 Sep 2020 20:42 #180586
by Hakan
Replied by Hakan on topic Cannot get example below from docs to work.
Isn't it the FEATURES that has to be set for _ini?
[RS274NGC]
FEATURES = 4
from the section above the given example in the docs.
[RS274NGC]
FEATURES = 4
- jeoslislo
04 Sep 2020 10:46 #180651
by jeoslislo
Replied by jeoslislo on topic Cannot get example below from docs to work.
LinuxCNC/AXIS version 2.7.15
linuxcnc.org/docs/devel/html/gcode/overv...tml#gcode:parameters
4. HAL pins and INI values
From the docs:
The names are not case sensitive - they are converted to uppercase before consulting the ini file.
From the docs:
- jeoslislo
04 Sep 2020 10:56 #180653
by jeoslislo
It works with FEATURES = 4
I am running vers 2.7.15. Should I be using a later version? What is the easiest way to update?
- BeagleBrainz
- Visitor
04 Sep 2020 10:58 #180654
by BeagleBrainz
Replied by BeagleBrainz on topic Cannot get example below from docs to work.
Depends on how you installed Linuxcnc.
The easiest way is to give some more info.
- jeoslislo
04 Sep 2020 11:28 #180658
by jeoslislo
I installed it years ago, most likely from the linuxcnc install CD.
- BeagleBrainz
- Visitor
04 Sep 2020 11:32 #180660
by BeagleBrainz
Any idea if it's Ubuntu or Debian ?
Any idea of which version ?
- jeoslislo
04 Sep 2020 11:33 #180661
by jeoslislo
I can live with using FEATURES= 4 instead of INI_VARS = 1 in the .ini file if updating my version is going to require a major effort
