Touch Plate/Tool Setter Test
- Project_Hopeless
- Thank you received: 10
09 Sep 2020 01:47 #181351
by Project_Hopeless
Touch Plate/Tool Setter Test was created by Project_Hopeless
I'm taking a chance on an inexpensive tool setter similar to this but much cheaper.
Tool Setter
I thought I came across a post on this site where someone modified their touch plate routine to perform multiple reads and store the results to a file.
I just started to setup for an auto Z touch-off button in Axis. While I'm at it I'd like to add the check/test function.
Can anyone provide link(s)?
Tool Setter
- Thank you received: 7468
04 Oct 2020 17:33 #184855
Replied by tommylight on topic Touch Plate/Tool Setter Test
Bumping this in case someone who can help missed it.
The following user(s) said Thank You: Project_Hopeless
- Project_Hopeless
06 Oct 2020 00:36 #185022
by Project_Hopeless
Replied by Project_Hopeless on topic Touch Plate/Tool Setter Test
I have the auto touch-off subroutine working now.
I did find in the Probe section Probe Logging. Doesn't look too difficult, I'm going to give that a whirl!
This test is not urgent, just more of a curiosity how consistent my inexpensive tool setter is.
- Project_Hopeless
24 Oct 2020 00:13 #187052
by Project_Hopeless
Success!
Tool Setter Video
Ignore the video shake, that something weird with the iPhone video.
For my purposes this tool setter is not bad for $18. The over travel protection did come in handy
On center I'm getting +-2 10thou. For a 1/4" bit if I'm off 1/2 the diameter I'm still +- 1.3 thou.
Results Graph
My code is not elegant but it works.
Cheers!
Tool Setter Video
Results Graph
o<tool_setter_test> sub
; rev. 2
; predefined values
#1=6.35 (tool diameter in mm 1/4")
#9=150 (locate speed mm/min.)
#10=50 (Probe speed mm/min.)
#11=500 (retract speed mm/min.)
#12=800 (rapid speed mm/min.)
#20=5 (number off center points >> polar array size >> or set to 4 for rectangle tool setter)
#21=3 (repeat array measures)
#22=[360/#20] (array angle)
#23=4 (cumulative angle)
#24=4 (tool diameter divisions 1/4, 1/2, 3/4 etc.)
#100=[#20*#21] (loop limit center test)
#101=0 (loop counter)
#102=[#20*#21] (total measures off center test)
#103=[#1/#24] (loop counter off center array)
; Set the Reference Zero to compare all additional measurements
G21 (use metric G21)
G10 L20 P0 Z0 ( Set current Z position to 0 so Z probe motion is down )
G38.2 Z-25 f#9 (move fast towards tool setter and locate)
G91 (Incremental distance mode)
G1 Z3 f#11 (Rapid Z up 3mm)
G38.2 Z-25 f#10 (move slow towards tool setter and set reference zero w/error detect)
;G38.3 Z-25 f#10 (move towards tool setter and set reference zero w/o error detect in sim mode)
G10 L20 P6 X0 Y0 Z0 ( Set X,Y,Z=0 at point where probe triggers with offset of 0 reference)
G90 (absolute distance mode)
G59 G0 (coordinate system #6 P6 G59)
(LOGOPEN,tool_setter_test_results.txt)
; Tool On Center Probe Loop
O1 while [#101 lt #100]
;G38.3 Z-5 f#10 (probe w/o error detect in sim mode)
G38.2 Z-25 f#10 (probe w/error detect)
;( store position data)
(LOG,G1 #101 X#5061 Y#5062 Z#5063 G54 X#5321 Y#5322 Z#5343)
#101=[#101+1]
O1 endwhile
O3 while [#103 LE #1]
#101=0 (loop counter reset)
O2 while [#101 lt #102]
G1 X[#103*SIN[#23]] Y[#103*COS[#23]] f#11
G38.2 Z-5 f#10 (probe w/error detect)
(LOG,G1 #101 X#5061 Y#5062 Z#5063)
#101=[#101+1] (counter inc)
#23=[#23+#22] (angle inc)
O2 endwhile
#103=[#103+#1/#24] (counter/dia inc)
#23=0 (cumulative angle)
O3 endwhile
(LOGCLOSE)
G1 X0 Y0 f#11
G54
o<tool_setter_test> endsub
Cheers!
