mesa 6i25 failed to install mesaflash configuration
- aleksamc
- Thank you received: 67
09 Sep 2020 09:11 - 09 Sep 2020 09:30 #181404
by aleksamc
mesa 6i25 failed to install mesaflash configuration was created by aleksamc
I want to try configuration for hostmot drive as written in manual:
mesaflash --device 5i25 --write 5i25 <config.bit>
but I get error
"no 5.25 device found"
I changed only jumpers for power supply W1, W2 - Up.
Should I change jumpers for PCI clock?
When I turn on pc, board 6.25 light up 2 last Leds with red and lights-down. When PC is running, the doesn't lights.
Edited:
I change clock freaquency to 66MHz (for PCIE).
I get another error:
I use last 2.8.0 version of ISO. PC is x64 bit system with core i3 CPU
but I get error
Edited:
Error: BootSector is invalid
Last edit: 09 Sep 2020 09:30 by aleksamc.
- Thank you received: 5321
09 Sep 2020 15:29 - 09 Sep 2020 15:29 #181458
Replied by PCW on topic mesa 6i25 failed to install mesaflash configuration
1. A 6I25 _must_ be jumpered for 33 MHz if using 5I25 firmware
2. To write a new bitfile, you would run mesaflash like this:
sudo mesaflash --device 5i25 --write somebitfile.bit
Last edit: 09 Sep 2020 15:29 by PCW.
- aleksamc
09 Sep 2020 18:52 - 09 Sep 2020 19:03 #181486
by aleksamc
Replied by aleksamc on topic mesa 6i25 failed to install mesaflash configuration
As I understand, on official cite present only firmware for 5i25.
But when I run mesaflash with
"sudo mesaflash --device 5i25 --write 5i25_7i77x2.bit"
I get error
" Boot sector is invalid"
I get error
Last edit: 09 Sep 2020 19:03 by aleksamc.
09 Sep 2020 19:13 #181488
At one time mesaflash had problems with 64 bit OS's
Can you try the latest mesaflash?
github.com/LinuxCNC/mesaflash
- aleksamc
09 Sep 2020 19:22 #181489
by aleksamc
I run mesaflash --write with function --fix-boot-block
and process is stuck under
"erasing sector 0 for boot block" and it stuck.
Can I stope that process?
09 Sep 2020 19:25 #181490
Is the 6I25 jumpered for 33 MHz?
- aleksamc
09 Sep 2020 19:27 #181491
by aleksamc
yes, i moved them back
09 Sep 2020 19:31 #181492
OK I guess the first thing is to see if the card still works and is detected
If you power cycle the system and run:
lspci -vv | grep 2718
what do you get?
what do you get?
- aleksamc
09 Sep 2020 19:43 - 09 Sep 2020 19:46 #181494
by aleksamc
I get
DPIO module: Device 2718 : 5125 (rev 01)
Device 2817 : 5125
And also, I think I reinstalled mesaflash but how to check if it's updated?
Problem is same ... boot sector is invalid
Device 2817 : 5125
Last edit: 09 Sep 2020 19:46 by aleksamc.
09 Sep 2020 20:04 #181499
Did you install the latest mesaflash? (from the link I provided)
Did you try just reading the current configuration:
sudo mesaflash --device 5i25 --readhmid
