Debian 7 Wheezy install and missing loadrt
09 Sep 2020 10:02 #181407 by ramaral
Hey Guys,
After downloding and installing Debain Wheezy 7 on a AMD64 machine, I noticed it did not come with loadrt (and likely other missing programs). My PC, does not have a parallel port, so I bought one but need to install the driver that came with it. I bought a NetMos 9900 board. I built the driver for this board from the source the manufacture supplied and got a 99xx.ko file. Do I simply load this driver into the kernel now - if so how? Also, why didn't my Wheezy installation have loadrt? Thanks.
  • Moderator
  • Moderator
09 Sep 2020 13:57 #181445 by tommylight
Replied by tommylight on topic Debian 7 Wheezy install and missing loadrt
Loadrt is a LinuxCNC function, so it is installed and functioning if there is LinuxCNC there.
And there is no need to compile and install any driver for parallel ports, Linux handles that nicely.
NetMos boards have always worked for me ( had over 20 of them).
Now, did you install the board into the PC?
Open a terminal and type
sudo lspci -v | grep par
and paste here
09 Sep 2020 15:02 #181454 by andypugh
Replied by andypugh on topic Debian 7 Wheezy install and missing loadrt
You are aware that Wheezy is a long time out of support?
loadrt is only available inside hal.
Does
halcmd loadrt hal_parport
work?
09 Sep 2020 16:59 #181465 by ramaral
Replied by ramaral on topic Debian 7 Wheezy install and missing loadrt
Sorry, I haven't played with LinuxCNC in awhile, yes, loadrt is an internal HAL command and it is there if I type "halcmd loadrt". When I execute "lspci -v | grep par" I get no results, however if I run without "| grep par" I see this in the long list of stuff:
01:00.0 Parallel controller: NetMos Technology Device 9900 (prog-if 03 [IEEE1284])
Subsystem: Device a000:2000
Flags: fast devsel, IRQ 10
I/O ports at ac00 [disabled]
I/O ports at a800 [disabled]
[virtual] Memory at fdeff000 (32-bit, non-prefetchable) [size=4K]
[virtual] Memory at fdefe000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
09 Sep 2020 17:05 #181467 by andypugh
Try this:
halrun
loadrt hal_parport cfg="0"
show pin
(you can also try cfg="ac00")
09 Sep 2020 17:31 #181470 by ramaral
When I run above, I get:
Error: could not insert module /usr/realtime-3.4-9...../hal_parport.ko: No such device
exit value: 1
insmod for hal_parport failed, returned -1
running dmesg says:
PARPORT: ERROR: linux parport 0 not found
09 Sep 2020 17:33 #181471 by ramaral
should I install the 99xx.ko driver that came with the board?
09 Sep 2020 17:39 #181474 by andypugh
No, don't install any drivers.
See if there is anything in the BIOS (though I wouldn't expect here to be for a PCI card)
And try the ac00 address (and all the others) to see if any of them work.
09 Sep 2020 18:04 #181478 by ramaral
Using address "ac00" seemed to work - I don't know why exactly. At least I didn't get an error message. I don't have the machine here to try it. I still don't get anything with sudo lspci -v | grep par, but running sudo lspci -v shows more details in the "Capabilites" section under the parallel port.
I still don't understand what's happening under the hood. Is there some good current tech documentation you can direct me to gives a bigger picture of how things work? Thanks for your help so far!
