OK to upgrade working linuxCNC from Mint 19 to 20?
09 Sep 2020 21:16 #181513 by pmconsulting
I have a working install of LinuxCNC on Mint 19.latest. Can I upgrade that to Mint v20 or does this require a complete reinstallation?
  • Moderator
  • Moderator
09 Sep 2020 21:52 #181520 by tommylight
You can but it will require creating a snapshot of the existing system, downloading a lot of stuff that is usually much more than 2GB of the ISO image and will in total last much longer. I did try it but the moment it told me to create a snapshot i just inserted the Mint20 USB and proceeded on a new install and never looked back.
Do make a copy of the configs and other comps if you have any in use.
09 Sep 2020 22:04 #181522 by cmorley
when i tried compiling linuxcnc in mint 20 I noticed it seems python 2 was called python2 rather then python - which breaks the build system.
Did you try compiling linuxcnc?
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
09 Sep 2020 22:31 #181524 by BeagleBrainz
Replied by BeagleBrainz on topic OK to upgrade working linuxCNC from Mint 19 to 20?
RIP builds fine and passes all tests. Building packages fails.
Personally I’d stay with 19.x
It’s still LTS.
Mixing in Debian packages on a Mint system gives issues with building and installing the Linuxcnc dev package. Ideally you want all your packages from the same ecosystem.
10 Sep 2020 00:21 #181528 by cmorley
Hmm interesting -i'll investigate further.
  • BeagleBrainz
  • Visitor
  • Visitor
10 Sep 2020 00:56 #181532 by BeagleBrainz
I'd like to add that I was only trying with v2.9.
I think there might be a need for a stanza for Mint20 in debian/rules. (The lsb_release values for Mint 20 are a tad different to Mint 19.x)
Is there a way to pass or override values with debuild ?
10 Sep 2020 04:21 #181549 by cmorley
Were you compiling with python3 by chance?
  • BeagleBrainz
  • Visitor
  • Visitor
10 Sep 2020 04:52 #181551 by BeagleBrainz
Yep.
I didn't try with python2. At the moment it's more of an academic thing with Mint 20. Maybe once there is a point release I'll really look into it.
RIP & python3 built & passed the tests but there was an issue with the DRO characters in the back plot in Axis.
Once I've sorted out the spindle on my mill and got all the new MESA goodies hooked up I'll have another shot.
10 Sep 2020 04:55 #181552 by cmorley
Well that explains it :) I specifically said python 2 trouble.
linuxcnc isn't completely python3 yet.
  • BeagleBrainz
  • Visitor
  • Visitor
10 Sep 2020 06:20 #181556 by BeagleBrainz
Sorry mate about the mess up.
python-gtk2 seems to be a stumbling block with Mint 20
Time to create page: 0.187 seconds
