Anyone willing to help bring jog-while-paused back into master?
- Thank you received: 2181
23 Feb 2021 00:17 #199787
There has been no movement. It is currently above my programming skills and the bar o understand linuxcnc's internals is pretty high for an outsider to pick up.
Never say never...
Replied by cmorley on topic Anyone willing to help bring jog-while-paused back into master?
Was there something happening since September last year e.g. opening a new Branch?
I am also very interrested in the jog-while-paused feature and willing to support a port to Master.
But i think i have not enough experience in the linuxcnc internals to do it on my own.
Never say never...
- biqut2
- Thank you received: 5
23 Feb 2021 02:38 #199792
by biqut2
Replied by biqut2 on topic Anyone willing to help bring jog-while-paused back into master?
This would be a very handy feature. On a Milltronics control you can put HDW into your program and it will cause the machine to halt execution of code and allow you to handwheel and manipulate the machine. Once you press enter it continues automatic execution of the rest of the program. This is extremely useful in a job shop or with one off setups. I use this feature daily and would love to have it in LinuxCNC too.
- mic
- Thank you received: 9
07 Mar 2021 17:00 - 07 Mar 2021 18:50 #201314
by mic
Replied by mic on topic Anyone willing to help bring jog-while-paused back into master?
For people who are interrested in the jog-while-paused feature and / or want to support a port to master:
I tried to port the jwp-feature to master:
github
-> currently it´s not working
(some Errors on Resume)
The statemachine from the Wiki is already implemented. Because of an unknown reason emcmotStatus->resuming in control.c never becomes true - it should be set in the Resume-Command-Handler in command.c.
I have to dig deeper into lcnc-internals.
Another current understanding problems:
- what´s the use of v-tables in machinekit (i think it works anyway but i want to understand)?
If someone has good recommendations or wants to join, you are welcome
github
Last edit: 07 Mar 2021 18:50 by mic.
10 Mar 2021 06:06 #201624
Is there a git branch?
- mic
10 Mar 2021 16:03 - 10 Mar 2021 16:06 #201658
by mic
I´ve forked lcnc and created a branch "jwp" with github link in the post above.
Currently it´s working basicaly. Jogging with an additional HAL Component works in pause-state but switching back to primary queue gives a tcqput error after a while. Do you know how pause and resume is handled by the UI? I was not able to find the component which is calling the emcmotCommandHandler.
Last edit: 10 Mar 2021 16:06 by mic.
- Thank you received: 7478
10 Mar 2021 18:24 #201672
Replied by tommylight on topic Anyone willing to help bring jog-while-paused back into master?
I might be a bit out of sync with the forum, but have a look at PlasmaC or QTPlasmaC, pretty sure it uses jog-while-paused for recovery mode and it can be also driven backwards through the gcode to a certain point while paused.
PhillC did a magnificent job on implementing those features for Plasma use.
There are sims included with LinuxCNC version 2.8 and Master/2.9.
10 Mar 2021 21:20 #201721
If it does - it uses different technology to do it - probably external offsets.
This adds ability to have multiple command queues and switch between them.
This would mean jogging while paused will honour limits etc.
and maybe more importantly, this could be useful for other things.
Chris
Chris
Time to create page: 0.203 seconds
