Anyone willing to help bring jog-while-paused back into master?
5 years 7 months ago - 5 years 7 months ago #201314 by mic
For people who are interrested in the jog-while-paused feature and / or want to support a port to master:
I tried to port the jwp-feature to master:
github
-> currently it´s not working :whistle: :laugh: (some Errors on Resume)
The statemachine from the Wiki is already implemented. Because of an unknown reason emcmotStatus->resuming in control.c never becomes true - it should be set in the Resume-Command-Handler in command.c.
I have to dig deeper into lcnc-internals.
Another current understanding problems:
- what´s the use of v-tables in machinekit (i think it works anyway but i want to understand)?
If someone has good recommendations or wants to join, you are welcome :)
Last edit: 5 years 7 months ago by mic.
5 years 7 months ago #201624 by cmorley
5 years 7 months ago - 5 years 7 months ago #201658 by mic
I´ve forked lcnc and created a branch "jwp" with github link in the post above.
Currently it´s working basicaly. Jogging with an additional HAL Component works in pause-state but switching back to primary queue gives a tcqput error after a while. Do you know how pause and resume is handled by the UI? I was not able to find the component which is calling the emcmotCommandHandler.
5 years 7 months ago #201672 by tommylight
I might be a bit out of sync with the forum, but have a look at PlasmaC or QTPlasmaC, pretty sure it uses jog-while-paused for recovery mode and it can be also driven backwards through the gcode to a certain point while paused.
PhillC did a magnificent job on implementing those features for Plasma use.
There are sims included with LinuxCNC version 2.8 and Master/2.9.
5 years 7 months ago #201721 by cmorley
If it does - it uses different technology to do it - probably external offsets.
This adds ability to have multiple command queues and switch between them.
This would mean jogging while paused will honour limits etc.
and maybe more importantly, this could be useful for other things.
Chris
Time to create page: 0.127 seconds
