- Thank you received: 2181
I know about run from here. I tested that a lot during development of my app.tommylight wrote: It is and it does have run from here
Yes, that's an interesting use case. Could be valueable for lathe with milling heads or the like. Great. But lathe with milling head is a typical use case for two instances of linuxcnc, so JWP might be a sync point of both instances.cmorley wrote: JWP allows an alternate motion queue to be switched in and out.
So it preserves the machine state at pause, runs another motion list then, adds a move to blend back to the original motion queue state.
This could be useful for more then JWP.
mic wrote: Was there something happening since September last year e.g. opening a new Branch?
I am also very interrested in the jog-while-paused feature and willing to support a port to Master.
But i think i have not enough experience in the linuxcnc internals to do it on my own.
