SSerial Port Numbering 7i92 & 7i74
- BeagleBrainz
- Visitor
12 Sep 2020 03:26 #181817
by BeagleBrainz
SSerial Port Numbering 7i92 & 7i74 was created by BeagleBrainz
Just being a little pedantic and what to check my thinking.
I get that the ports on the 7i76 map to the ports 0 & 1 on channel 0 of the 7i92.
I can see that on the 7i92 channel 1 has 6 ports, are they 0-5, assuming the ports are 0-7.
Or are they 1-6, assuming the ports are 1 - 8.
On the 7i92_7i76_7i74D.pin file the Rx\Tx lines start counting at 1.
The 7i74 manual has Rx\Tx lines start counting from 0.
The 7i92 has only 6 Rx\Tx .
So what is the mapping and how do these map to the hostmot2 sserial setup parameter ? And what is the mapping to the physical 8 port connector on the 7i74.
I hope I've explained the issue I have myself in.
- BeagleBrainz
- Visitor
12 Sep 2020 07:59 - 12 Sep 2020 08:05 #181846
by BeagleBrainz
Replied by BeagleBrainz on topic SSerial Port Numbering 7i92 & 7i74
Thanx, you've all been a great help, but I sorted it out.
Actually I'm going to have a whinge.
I do As Much as I can to help out, creating ISOs, keeping a repo for the ISO yet when I have a question, mostly no one chimes in until Rod replies, once Rod chimes in others do as well. And Chris, he'll help out when there's code issues.
Do I smell ?
Have I pissed you all off ?
My questions don't make sense ?
Or should I just chuck out the MESA hardware, finish with Linuxcnc and buy a copy of Mach4. And No don't ask to buy any of the Mesa gear cos I aint gunna do no one no favours if it comes to that.
Do I smell ?
Last edit: 12 Sep 2020 08:05 by BeagleBrainz.
- Thank you received: 2164
12 Sep 2020 08:21 - 12 Sep 2020 08:22 #181850
Replied by Aciera on topic SSerial Port Numbering 7i92 & 7i74
Hm,
If your kidding :
If not: I haven't done the statistics but maybe
a) your questions are advanced and only few users can help
b) you find the solution before anybody has a chance to answer
c) you're having a bad day
Because we all love you!
If your kidding :
Last edit: 12 Sep 2020 08:22 by Aciera. Reason: kiss
- Clive S
- Thank you received: 486
12 Sep 2020 08:32 #181853
by Clive S
Replied by Clive S on topic SSerial Port Numbering 7i92 & 7i74
Rob I'me shocked.
I looked back to see what the problem was and I found two posts but I did not see a question.
I could not have helped anyway as my skill set is not strong enough.
You have done a great deal to help me and others, I for one really do appreciate the time and effort you do put in.
The trouble with a global forum is the time differences can be vast.
Please don't get despondent.
- Thank you received: 4144
12 Sep 2020 08:34 #181854
Replied by rodw on topic SSerial Port Numbering 7i92 & 7i74
I'm out of this one. I have no clue about 7i92s et al!
I do think the kind of stuff you do is pretty techo and way past my pay grade...
With social distancing none of us have any idea if you smell or not!
You certainly have not pissed me off!
and x 2 we all love you!
- Thank you received: 7468
12 Sep 2020 21:12 #181934
Replied by tommylight on topic SSerial Port Numbering 7i92 & 7i74
I think this was addressed at me as i do have several systems working with 5i25 or 7i92 and 7i77 and (more importantly) with 7i74. Shame on me !
One of those systems uses a custom firmware that PCW made for me ( eternally grateful to PCW for that as it saved me a lot of work ) that has 6 SSI encoder channels and 2 normal SSerial channels . Now those 6 SSI channels start from 0 at the bottom far port (this is all looking at the 7i74 from above, RJ45 connectors on the right side), 1 is bottom near port, and so on.
For connecting 7i70 and 7i71 to 7i74 i just plug them in and check the "show hal configuration" from the "machine" menu in Axis GUI, then edit the hal file accordingly.
Time to create page: 0.195 seconds
