Z-movement stopped working in dual Y XYYZ 4-joint mode system
- radek_marko
- Thank you received: 18
12 Sep 2020 16:34 - 12 Sep 2020 17:24 #181896
by radek_marko
Z-movement stopped working in dual Y XYYZ 4-joint mode system was created by radek_marko
Hi, I'm in the process of putting together plasma CNC. Now I'm stuck on the following issue:
Before I've changed from 3-joint I could move Z-axis (PgUp/PgDown or +/-) buttons on the screen.
I haven't changed pins for the motor DIR and PUL, when I test it via stepconf it does work.
I have changed HAL as it was required for the 4th joint.
When LinuxCNC starts the config from fresh it displays joints as numbers from 0 to 3. Before execution of "HOME ALL" I can select joint 3 (z-axis) and using +/- buttons on the screen I can feel the motor movement (but is tiny not as per expected move). After "HOME ALL" when Linux CNC is in axis mode the move of z by +/- on the screen does not move motor at all.
My setup:
x-axis on joint 0 (min and home on single input)
y-axis on joint 1 and joint 2 (min and home as one on each joint)
z-axis on joint 3 (no sensors)
I'm attaching my conf and INI
I'm a complete newbie and do not know where to start.
Please help!
My setup:
Please help!
Last edit: 12 Sep 2020 17:24 by radek_marko. Reason: New info found
- Thank you received: 2176
12 Sep 2020 18:18 #181907
Replied by Aciera on topic Z-movement stopped working in dual Y XYYZ 4-joint mode system
Looks like you have set your limits for the Z axis wrong (it can't move because you told the controller that the axis lenght is 0.002):
[AXIS_Z]
MAX_VELOCITY = 64.94140625
MAX_ACCELERATION = 750.0
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
[AXIS_Z]
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 0.001
- radek_marko
13 Sep 2020 09:41 #182002
by radek_marko
Replied by radek_marko on topic Z-movement stopped working in dual Y XYYZ 4-joint mode system
Thank you very much for your help!
I have changed MAX_LIMIT for AXIS and JOINT to 120.0 (mm) and it now allows me to move z-axis.I have made one more change. The movement was reversed PgUp was moving the axis down and PgDown was moving axis up. I've changed the scale to "-" value and now I can move it as expected.
Now time to move to the integration of plasma and the torch height controller.
13 Sep 2020 11:38 #182006
Thanks for reporting back. I'm glad you got it working.
Time to create page: 0.598 seconds
