proximity sensor for home/limit switch
- motal2004
- Thank you received: 16
13 Sep 2020 00:49 #181951
by motal2004
proximity sensor for home/limit switch was created by motal2004
Hello people,
Quick question regarding using proximity sensor for home/limit switches... In general whats best practice to used in plasma cnc environment a NPN or PNP and 5V or 6V-36V? using a mesa 7i96 board.
- Thank you received: 4144
13 Sep 2020 01:38 #181956
Replied by rodw on topic proximity sensor for home/limit switch
I would use PNP. The 7i96 can use either but the other boards (ie 7i76e et al) can use PNP out of the box and NPN requires a pull up resistor.
The following user(s) said Thank You: motal2004
- Thank you received: 2164
13 Sep 2020 05:54 #181979
Replied by Aciera on topic proximity sensor for home/limit switch
Also for noise immunity its better to use a higher voltage like 24V if possible.
Time to create page: 0.073 seconds
