Hardware Reccomendations
  • htdave
  • htdave's Avatar Topic Author
  • Senior Member
  • Senior Member
14 Sep 2020 03:43 #182051 by htdave
Hardware Reccomendations was created by htdave
I am looking at converting my Hugong Plasma Cutter (www.hugongwelds.com/product/detail113.htm) over to LinuxCNC.
The plasma cutter runs servo motors for the gantry (2 for X axis and 1 for Y axis) and DC motors without any feedback for the THC and an air scribe. The Air scribe has an ohmic sensor for height control.
The servo motors are controlled by Panasonic MBDJT2210 220V motor controllers.
My reasons for wanting to change to LinuxCNC are twofold. 1) The Hugong software does not allow Plasma cut height to be set without THC, which means small holes have to be cut at pierce height, producing excessive taper.
2) I would like to add milling capability to the plasma cutter so that critical holes can be cut undersize, and then milled to the correct size - eg a 20mm hole could be cut at 19mm and then milled out to 20mm.
As I am new to both LinuxCNC and Linux in general, can anyone recommend a suitable computer as a starting point? Will I need a Mesa card as well?
  • Moderator
  • Moderator
14 Sep 2020 08:41 - 14 Sep 2020 21:32 #182061 by tommylight
Replied by tommylight on topic Hardware Reccomendations
1 LinuxCNC with PlasmaC can do all that and much more.
2 Milling anything plasma cut with HSS tools is not possible due to hardening on the cut surface, but it should be possible with Carbide tools.
For PC, i know of many that work but not by model number, but from advice from PCW most of us use HP 8300. For SBC someone else might chime in on what works as i do not use them.
Last edit: 14 Sep 2020 21:32 by tommylight. Reason: typo
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
14 Sep 2020 08:53 #182063 by BeagleBrainz
Replied by BeagleBrainz on topic Hardware Reccomendations
Although a little pricey, or not, the Odroid H2+ maybe an option. And there is an ISO to suit.
  • htdave
  • Senior Member
  • Senior Member
15 Sep 2020 03:44 #182176 by htdave
Replied by htdave on topic Hardware Reccomendations
Thanks for the replies.
It looks like I have a lot of reading to do to get my head around linuxcnc.
The Odroid H2+ is about $240 here in Australia, so not the cheapest, but I am happy to pay if it is going to be a reliable option and easier to setup.
  • BeagleBrainz
  • Visitor
  • Visitor
15 Sep 2020 04:25 #182182 by BeagleBrainz
Notice the Southern Cross Flag as my Avatar ?
Guess where I'm from ;)
It's cheaper to buy the Odroid directly from HardKernel, even including shipping, than the local suppliers.
Odroid H2+
2 x 4GB Ram
1 set SATA data & power cables to suit
Extra BIOS battery
External Power Button
Power Supply
AUD $304 shipped, delivery time was 6 days from placing of order to having it up & running.
I opted out of the emmc module and went for Crucial P1 500GB NVME drive which added $99 from a local shop on a Sunday. Could have gone for a SSD or a cheaper NVME but that was all they had in stock. I reckon if I did order something cheaper I'd be waiting longer than 6 days...aint AusPost great ?
15 Sep 2020 09:00 #182195 by rodw
Replied by rodw on topic Hardware Reccomendations
We Aussies are taking over the Forum!
I bought mine locally with 4 Gb RAM, tiny 64 Gb SSD, Wifi and power supply. I Don't think Linuxcnc will benefit from 8 gb RAM but the Beagle might have more insight into that.
  • htdave
  • Senior Member
  • Senior Member
15 Sep 2020 09:20 #182198 by htdave
What Mesa boards are you guys using with the Odroid?
15 Sep 2020 09:26 #182200 by rodw
I have not used any!
Any Mesa ethernet board will work just as well as any other. Popular options are the 7i96 (limited I/O,no dedicated spindle control great for Plasma), 7i76e (more IO, 2 dedicated MPG inputs, spindle control with encoder)
Or for servos, 7i92 and attached 7i77
Then there is the new 7i95 and.....
  • BeagleBrainz
  • Visitor
  • Visitor
15 Sep 2020 10:13 #182204 by BeagleBrainz
Currently my setup is 7i92 7i76 7i73 with a 7i74 & 7i83 on the bench for the AC servo drive for the spindle.....as can be seen I don't have a plan.
To be fair I just bought the 7i73 for fun and to mess around with.
15 Sep 2020 10:25 - 15 Sep 2020 10:31 #182206 by anfänger
Replied by anfänger on topic Hardware Reccomendations
It depends on what you need. I needed an analog +-10V signal for servos. And some Io‘s in the control and some Io‘s in the electrical cabinet, so I opted for 7I92H, 7I77, 7I74 (which might have been Not necessary but convenient), 7I70 and 7I71.
But is is a machining center with a lot of IO‘s and things to play around with and today there are more Ethernet cards available.
So First I would check what Io‘s your machine has and how the servo drives are controlled.
Last edit: 15 Sep 2020 10:31 by anfänger.
Time to create page: 0.258 seconds
