emc/task/emctask.cc 411: interp_error: File not open
- wade
15 Sep 2020 02:34 #182173
by wade
emc/task/emctask.cc 411: interp_error: File not open was created by wade
Dears
I 've installed linuxcnc2.8 on my board with debian9 ,kernel 4.19.132-cip30-rt59.
When I run linuxcnc with my config, it appears the following errors
what should I do to solve it?
here is my .hal config
loadusr -W lcec_conf ./ethercat-conf_X.xml
loadrt lcec
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt not count=1
addf lcec.read-all servo-thread
addf not.0 servo-thread
addf lcec.write-all servo-thread
setp lcec.0.0.ControlWord-1 1
setp lcec.0.0.ControlWord-2 1
#net Xachse_fb lcec.0.0.PositionActualvalue => axis.0.motor-pos-fb
#net Xpos => lcec.0.0.TargetPosition
#net Xachse_AF axis.0.amp-enable-out => lcec.0.0.ControlWord-0
#net Xachse_AF => lcec.0.0.ControlWord-3
#net Xachse_AF => lcec.0.0.ControlWord-5
Thanks & Best Regards
Wade
loadrt lcec
loadrt trivkins
loadrt not count=1
Wade
- BeagleBrainz
- Visitor
15 Sep 2020 03:39 #182175
by BeagleBrainz
Replied by BeagleBrainz on topic emc/task/emctask.cc 411: interp_error: File not open
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = nc_subroutines:/home/frank/linuxcnc/configs/ethercat
LOG_LEVEL = 9
Is the line in red correct ?
If you look through the debug file you may also find reference to the issue. Or maybe if you attach it to your next post.
LOG_LEVEL = 9
- wade
15 Sep 2020 03:49 #182177
by wade
Replied by wade on topic emc/task/emctask.cc 411: interp_error: File not open
Hi,Platinum
Thank you,I‘ll change it and try again。
Time to create page: 0.072 seconds
