Velocity tuning of YY2 gantry
- OT-CNC
- Thank you received: 75
Thank you for your response and time to look over the config.
I'm guessing I had more then one of the same configs open when I saved out the wrong one reverting to the wrong scale. I just recalibrated and it's within .001" over 36 inches.
Thanks for the heads up on noise. The old control worked with current wiring but I don't like everything going through one big conduit. Horrible idea. Meaning VFD power to spindle, servo power, encoders and limits homes etc in close proximity. I did ensure all signal drains are connected to one star ground and only on the cabinet end.
Now I did come upon an issue with different ground potentials of the PC and control cabinet. PC is now powered off same source and has same ground potential. I would assume that could cause an issue. Running a part right now and hope it will not error out.
I will load the scope and recheck signals again at some point. Can I capture/save a screenshot in linux? I think gimp is loaded on my version. I wish halscope had a save to image feature.
- Thank you received: 1472
For example if you are running the old Wheezy Linuxcnc ISO, pull down from the menu bar Applications>Accessories>Screenshot.
Also if it helps you can try adjusting the encoder filter settings of the Mesa card. What the ideal settings might be for your machine will be dependent on a combination of your encoder resolution, maximum acceleration, and maximum velocity.
- OT-CNC
I now have a soft limit question. When I park the B or C rotary axis at it's soft limit I get en error that I'm on my soft limit. (It may have rounded up a small value past the soft limit, don't remember exact error message, maybe past soft limit) I don't get that message if I travel to the extents of my linear axes. Is there a reason for that? In other words, I can park the xyz at the end of travel but not the rotary. Also, during homing, if the home switch were not detected, would a rotary joint stop moving once it traveled past it's assumed soft limits or will it try to rotate say past 360 degrees looking for the home trigger? I can't really test this on this machine as it may wrap the wiring. I need some ideas on how to handle the rotary safeties.
I currently have to manually position the joint to location before home switch trip. If end user accidentally shuts down machine in wrong position, rotary may not find home correctly.
- OT-CNC
Well, it got tested by the end user. Appears rotary will try to seek home switch past the soft limit values. Is there a way to implement a rotary joint homing feature that stops homing if switch is not found within the soft limit boundaries? This would help prevent a rotary from wrapping all the way around if parked inadvertently past the switch.
- OT-CNC
Why can't a joint be made to start count before home is found? It could compare that count to an ini limit setting and if found to have exceeded it, pause and offer a warning. Then allow joint manual jogging to re-position to location before the switch and re-home to establish it's true position. This could be an added safety no?
