Hurco BMC40, problem with machining limits
- bruno2626
- Thank you received: 3
20 Sep 2020 06:38 #182824
by bruno2626
Hurco BMC40, problem with machining limits was created by bruno2626
I use gmoccapy and nativecam on my Hurco BMC40. I have some problem with the calculation of machining limits.
The best way to explain the problem:
The limits on the x-axis are shifted by 0.7mm from the very simple gcode.
The limits on the z-axis are shifted by 0.2mm. And Z=4.8 seems to be out of limits, but this is largely within the red frame of the machine limits.
For the z axis, I have the same problem as on my lathe with axis, but I can "run anyway". With gmoccapy, I cannot.
Thanks.
Bruno
Thanks.
Bruno
- bruno2626
20 Sep 2020 06:44 #182826
by bruno2626
Replied by bruno2626 on topic Hurco BMC40, problem with machining limits
- bruno2626
20 Sep 2020 16:47 #182924
by bruno2626
I checked, it doesn't depend on gmoccapy or nativecam.
It's possible to move this post to a more general section?
- Thank you received: 7468
20 Sep 2020 16:58 #182929
Replied by tommylight on topic Hurco BMC40, problem with machining limits
Did you test with Axis GUI?
- bruno2626
20 Sep 2020 17:02 #182931
by bruno2626
Yes, it's the same behaviour.
20 Sep 2020 17:09 #182933
Moved to " General LinuxCNC Questions ".
- bruno2626
20 Sep 2020 17:21 #182936
by bruno2626
Thanks tommylight.
20 Sep 2020 21:06 #182963
You are welcomed, always.
- bruno2626
21 Sep 2020 06:47 #183076
by bruno2626
I'll have to succeed. I tried a " in retrofit " configuration and it works. By copying the ini file of the problematic configuration into the older one, the limit fault appears.
The problematic ini file:
The ini without problem:
Bruno.
Bruno.
- bruno2626
21 Sep 2020 09:37 #183105
by bruno2626
Oops, I tried again and the problem is gmoccapy!
Time to create page: 0.179 seconds
